Faulty 360 HD-DVD need a Part? Will diy a fix
Discussion in 'Xbox Forums' started by a_friend, Dec 22, 2006.
  1. a_friend
    a_friend
    Oct 12, 2005
    863
    Ilford
    +20
    Bought from overseas and I have discovered that it decided to disconnect it self from time to time. I traced this down to it being a faulty mini usb socket.
    Now maplin don't supply these they only have plugs (go figure) does any one know where I can get one from part from ripping up an existing one or DIY-ing the rear to fit a larger USB socket.
    At the moment its working but I've had to wrap the cable round my Sona AV rack to give it some tension so the contacts connect.
  2. T800
    T800
    Dec 7, 2005
    2,986
    Cumbria
    +154
