fault with progressive scan on Grundig dvdr550
Discussion in 'Blu-ray & DVD Players & Recorders' started by albar, Mar 27, 2006.
  1. albar
    albar
    Mar 27, 2006
    4
    I have a Grundig dvdr550,i was setting it up when i pressed progressive scan,since that time ,i have not been able to get a picture on the television,therefor,i can't alter the setup.I've tried power off/power on with no result.
    Can anybody help please.
    yours
    albar
  2. mjbtin
    mjbtin
    Jan 13, 2005
    2,471
    116
    +614
    I am assuming the recorder is connected to the screen with a scart and not component cables this would account for no picture .
    If you connect the recorder to the screen with a composite video cable(yellow rca phono) you should then be able to bring the menu up on screen and change the setting from progressive to rgb if using a scart cable ,once setting has been changed you can remove the composite cable(yellow rca phono )
    Regards Martin.:)
