Fault with Phillips DVR880
Discussion in 'Blu-ray & DVD Players & Recorders' started by thehorse, Jul 14, 2004.
  1. thehorse
    thehorse
    I'm asking this question on behalf of my mum and dad, so apologies if some of rthe details are a bit sketchy.
    They were trying to record something last night on their DVR880. It looked like it was recording as usual. Unfortunately, when they wentr to play it back, the display said 'No Disc'. They were new discs - JVC DVD+RW discs - but on ejecting the disc and trying to play a pre-recorded one, again the display said 'No Disc'.
    Is this a fault which other users have encountered? Any quick fixes?
  2. tabatha
    tabatha
    Jun 9, 2004
    180
    16
    West Midlands, UK
    My first reaction would be that the optics may be dusty. It would be worth trying out a DVD "cleaner" disc in the drive. They can be bought from shops like HMV and Woolworths for less than a tenner. The cleaning disc has micro brushes that "stroke" the dust off the optic as the DVD "plays".
    If this does not sort the problem out, it may be that the machine has developed a fault and you will have to resort to a Philips service centre.
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,856
    Warwick
    +2,777
    A Philips machine developing a fault!?! Surely not!
  4. C.Wolf
    C.Wolf
    Mar 6, 2004
    392
    28
    Kent
    +26
    Try unplugging it from the mains for about a minute, then plug it back in . Apparentely this resets the software, it could just be a glitch.
  5. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    I'm sorry to be the bearer of unhelpful news,but there is not a single 880 out there that will not develop this fault.The machine is genuinely only suitable for a breakers yard.If a new machine,from as cheap as £200,is not an option,then contact Philips via their website.They have extended the warranty on these piles of junk to 2 years,due to this type of fault.A cd firmware upgrade will be temporary at best.Unless the machine has already been back to Philips,it will need a trip to their workshop.But you would save yourselves a whole lot of trouble by putting it in the nearest skip(yes,they are THAT bad) and buying a new Panasonic,Pioneer,Toshiba etc.
  6. michaelm
    michaelm
    Aug 13, 2001
    678
    Belfast
    +3
    You don't rate them highly then, Phelings? :D
    I was given a 980 with the same problem. I got it repaired a couple of weeks ago under (2yr) warranty. It didn't cost me anything so if I get 6 months out of it I'll be happy. Then I'll buy a cheaper machine with dv in/out. The current Umax/Yamada 8000 is reckoned to be pretty good, and only £150 at Richer Sounds. Cyberhome also have one waiting in the wings.
