Fault with Kef PSW1000 - any ideas?
Discussion in 'Subwoofers' started by Coolhand, Jul 15, 2005.
  1. Coolhand
    Coolhand
    Jan 17, 2002
    61
    +8
    My sub has started making a continuous noise. You switch it on, the lights are all ok, then the relay clicks and then shortly afterward it's starts a constant noise, the only way I can describe it is like a tone repeating 20 times a second.
    It's out of warranty so I could be stuffed, but just wondered if anyone had any ideas what it could be?
  2. steve2267
    steve2267
    I recently had a repair done on my Kef Sub, Kef have a standard £50 charge for repair.
    It works out cheaper postage if you remove the panel and just send that off.
    Regards.
