Fast transfer from cam to pc?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by swampyjim, Feb 17, 2005.
  1. swampyjim
    swampyjim
    I've managed to set up my Panasonic NV-GS11EB mini DV cam up to my PC via Firewire and I can transfer movies to my PC using various software, all working perfectly now.
    At the moment I have to play the entire tape and record it 'realtime' - ie it takes me an hour to transfer an hour of footage
    As the format on the mini DV tapes is digital, is there a way of transferring everything off a tape in one quick copy in the same way you copy jpgs off a digital camera?
    :lease:
  2. swampyjim
    swampyjim
    ah well - thanks anyway - i'll just have to be patient............... :boring:
  3. JohnFarrar
    JohnFarrar
    Feb 21, 2005
    14
    Cornwall, UK
    You could try Scenalyzer which does a great job of capturing video.
    HTH
    John
