Question fast and tight
Discussion in 'Subwoofers' started by silouette, Oct 2, 2017.
Tags:
  1. silouette
    silouette
    Mar 5, 2010
    715
    32
    Welwyn
    +84
    looking for a sub that is dynamic and fast rather than deep and fluffy, budget around 350pounds.
    Any thoughts, deep deep not my need but fast and tight is.
  2. Fella55
    Fella55
    Nov 7, 2006
    325
    46
    Surrey
    +120
  3. shotokan101
    shotokan101
    Jun 16, 2009
    75,777
    Glasgow
    +25,717
    ...or these and save a few quid - possibly even afford the XXls400....
    colosussxb | eBay
  4. Deleted member 598831
    Just a heads up. Subwoofers with a higher/optimised system Q tend to be fast and tight, although subs with an optimum Q 0.5, tend to be more accurate.
    It all comes down to system implimentation, and if its built proper.
    The bk subs.....for the money are very very good. I had dual 400's and they are nice in all respects of output.
  5. MemX
    MemX
    Feb 15, 2013
    3,724
    +1,206
    The effect your room has on the output is far more likely to be causing 'overhang', 'boominess', etc.
    Do you have electronic EQ in your system?
    Have you bought a calibrated microphone and downloaded Room EQ Wizard (REW) so that you can measure exactly what it is you might be having issues with currently?
  6. silouette
    silouette
    Mar 5, 2010
    715
    32
    Welwyn
    +84
    thanks for all the advice guys, am investigating options as i type
  7. Violator
    Violator
    Jun 19, 2007
    1,712
    116
    Chester
    +567
    Looking at the thread title I had to check I was on the right forum...
  8. shotokan101
    shotokan101
    Jun 16, 2009
    75,777
    Glasgow
    +25,717
    ...and you discovered you weren't - not with that Username ;) :D
    • Funny Funny x 3
    • Like Like x 1
    • List
  9. silouette
    silouette
    Mar 5, 2010
    715
    32
    Welwyn
    +84
    Always like to try and post an ambiguous title,just for a bit of light relief
  10. silouette
    silouette
    Mar 5, 2010
    715
    32
    Welwyn
    +84
    Ended up getting a SVS sb2000 way over budget ,turns out my very big viewing room needed some grunt. Managed to get an ex demo one at a acceptable price and the home trial just blew me away, Totally amazing. Never thought a piece of audio equipment could make such a difference to movie night enjoyment
