Far Cry and Vista 64bit?
Discussion in 'PC Gaming & Rigs' started by meansizzler, Sep 16, 2007.
  1. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    Does Far Cry work on Vista 64bit, if so what patches/updates do I need to make it run on vista and take advantage of it being a 64bit OS?..
  2. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    Far cry worked on 64-bit xp, and you could download a patch for better textures and stuff, no idea if this is vista compatable though.
  3. wormvortex
    wormvortex
    May 29, 2005
    5,765
    South of Heaven
    +443
    google would have gotten you an answer far quicker
  4. NinjaMonkeyUK
    NinjaMonkeyUK
    Aug 1, 2004
    1,008
    +265
    Far Cry works perfectly in Vista 64-bit. There are two patches which add up to about 1GB that add higher resolution textures & give you a longer draw distance. I'm playing through on Realistic mode for the second time at the moment on Windows Vista Home Premium 64-bit & it runs really smoothly.
    The patches are definitely worth the download.
  5. NinjaMonkeyUK
    NinjaMonkeyUK
    Aug 1, 2004
    1,008
    +265
  6. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    Hi Going to install fresh insall of far cry and both the 64bit updates, do I need to install any other patches i.e 1.4?, using Home Premium 64bit..
  7. NinjaMonkeyUK
    NinjaMonkeyUK
    Aug 1, 2004
    1,008
    +265
    If you're installing the 64-bit patch & extras, don't install the v.1.4 patch as that is meant for 32-bit versions of the game & will mess up your 64-bit installation.
    I literally just installed the 64-bit patch (v.1.3 or 1.33 from memory) & then installed the large texture pack.
    You can grab them from the link in my previous post.
  8. eaglemmoomin
    eaglemmoomin
    Jul 12, 2007
    2,395
    63
    Crawley
    +226
    I know I'm resurrecting an ancient thread. But how on earth did you get the blasted game to run? I've stuck the 64bit patches on (have'nt gone near 1.4 as its marked as 32 bit only). The game loads fine and the startup screen etc is all there however when I start an actual game after loading I basically get sod all (no textures very little in the way of objects) basically its unplayable. Any ideas as to whats going on? I've even tried compatibility modes but nothing doing there. I'm told that the 64 bit build will work on AMD/EMT64 based cpus so who knows whats going on?
    As it is I'm thoroughly remembering now why I loathe playing games on a PC now thanks to MS and there hopeless OS's. I had intended to have a quick go at 7:30 its now 11:20 and I've exhausted all my ideas?
  9. eaglemmoomin
    eaglemmoomin
    Jul 12, 2007
    2,395
    63
    Crawley
    +226
    Got it working in administrator mode witout compatibility mode. Cuh why should something this simple be so awkward.
  10. John Peterson
    John Peterson
    Nov 1, 2009
    My problem is that the game won't start with the Very High Lighting setting. I found out from here that the exact setting that's causing the problem is the r_Quality_BumpMapping setting. So if you have this problem too, you can have everything on the highest setting except this one.
    Another thing: V-sync has no effect, doesn't work. I have to use D3DOverride if I want v-sync. But that doesn't work with the 64-bit game.
  11. CraigofScotland
    CraigofScotland
    Jan 13, 2009
    5,287
    +894
    I run far cry on 64 vista . . just the usual upgrades, no bothers.
    Games poopoo tho :D
