Far Cry and Clone CD = Not happy families
Discussion in 'PC Gaming & Rigs' started by tuttonp, Oct 18, 2004.
  1. tuttonp
    tuttonp
    Jun 10, 2003
    6,809
    103
    Bristol
    +297
    This is really bugging me now.
    Installed Far Cry, worked fine.
    Installed Clone CD, Far Cry now reports I have cd/dvd emulation sw and to close it before starting the game.
    Stopped sw, Far Cry still refuses to load, argh!!
    Any suggestion how I close all the pertinent processes running clone cd to keep Far Cry happy??
    Don't really want to have to un-install it as it's a great package in its own right.
  2. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,117
    Southampton
    +262
    I have CloneCD & Farcry installed,with no problems.Have you tried installing CloneCD first,and then installing F/C - i.e the reverse order of how you installed it.Just a thought,as that's the order I installed it in,and all was ok.FYI,both F/C & Clone are patched to the latest versions.
    HTH
    Jerry
  3. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,117
    Southampton
    +262
    Just thinking about this further - when you stopped Clone - did you reboot?You may want to try stopping any Clone references loading on startup - go run>type "msconfig">startup,and uncheck any references to Clone or Eylaborate Bytes - apply,then restart.Start F/C,and see whether it works,now Clone has no processes running.
  4. Marc
    Marc
    Jul 8, 2004
    11,719
    Titchfield
    +1,101
    it depends whether you have the clonecd/dvd virtual drives enabled. i think by default it installs one. You will need to remove that and then the problem should go away.
  5. Sinzer
    Sinzer
    May 25, 2002
    5,823
    +1,117
    Nearly everyone I have seen hit by this problem find they have to completely uninstall Clone CD.
    The only other option is to install a no CD crack, this will be fine unless you want to play online.
  6. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    I had to uninstal clonecd too. Didn't bother me too much as I hardly used it and I kinda see ubisofts point.
    I hate rooting around for PCgame discs. They should let you permanently lock the games to your PC or something and allow you to install it on the HD.
    One reason I like steam.
  7. allanp
    allanp
    Jun 28, 2004
    1,060
    63
    +104
    Just download a no-cd crack? If you've bought the game then it can't really be illegal.
  8. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    Whether its illegal or not is beside the point I don't want to have to apply some dodgey third party crack to play without scrabbling around for a CD.
  9. Sinzer
    Sinzer
    May 25, 2002
    5,823
    +1,117
    Technically it is still illegal, and I agree there should be a way to lock it to your HD, I too hate having to use CDs to play games :(
