FAO Shockabuku
Discussion in 'Desktop & Laptop Computers Forum' started by Paul.B2, May 28, 2002.
  1. Paul.B2
    Paul.B2
    Mar 3, 2002
    1,934
    63
    Buxton, Derbyshire
    +195
    Hi mate, i noticed on another thread that you're using a Lindy VGA cable.
    Would it be this one?:
    Premium Gold S-VGA Monitor Cable (15HDM/15HDM), 10m
    Now with 25 year warranty!
    Gold Plated 15 Way HD Male to 15 Way HD Male
    Designed for highest quality monitor applications, including CAD, DTP and Multimedia installations when preservation of display is a major consideration
    Triple shielded 'low loss' coaxial cable, gold plated contacts and gold plated metal hoods assembled in accordance with 'EMC' compatible construction techniques
    Incorporating secondary internal screening which provides a high degree of EMI shielding with clearer signal transmissions and minimum distortion
    25 year warranty
    Priced at £38.50
    If thats the one you got, and you recommend it, then thats the one for me :cool:
    cheers,
    Paul.
  2. Guest
    That's the one I've got and it's superb, quite flexible as well which helps!
    Andy
  3. Pack Dude
    Pack Dude
    Feb 6, 2002
    876
    Lost In Space
    +98
    that was close, i was going to order a male to female cable. i see from above its a male to male i need for the 100e
    not that you would know from the panasonic webpage "PC IN RGB: D-sub HD 15-pin " at least i cant tell if its a male or female input from their webpage info
    i have panny on order and wanted the cable before it got here. most monitor extension cables are male to female
    i am glad i seen your post before i ordered
  4. Shockabuku
    Shockabuku
    Mar 5, 2002
    1,805
    Oxfordshire
    +166
    Hi Paul. Yep yep, that's mine too & it's a top-drawer cable....deffo worth the dosh.
  5. meep
    meep
    Apr 22, 2002
    782
    46
    Ireland
    +118
    Hi Guys,
    Could you post a source for purchase of this cable?
    meep
  6. Shockabuku
    Shockabuku
    Mar 5, 2002
    1,805
    Oxfordshire
    +166
    Go to Lindy and search for "Premium Gold S-VGA Monitor Cable". It'll give you a list of all the lengths they have.
