FAO: Nictry
Discussion in 'General TV Discussions Forum' started by Matthew Attoe, May 26, 2002.
  1. Matthew Attoe
    Matthew Attoe
    Dec 8, 2001
    702
    Norwich
    +11
    You mentioned in your reply to another of my posts that there was a picture rotation option on the 9607 in the standard menus.
    I couldn't see this in any of the options on the menus when i was having a play in the shop, so could you tell me where it is please?
    Many thanks
    Matthew
  2. spikeyboyo
    spikeyboyo
    Its in the setup menu - open the flap at bottom of remote and press two buttons together to get menu open - the item in the menu u want is called TILT.
    Spike
  3. nictry
    nictry
    Apr 28, 2002
    5,834
    Kent
    +652
    Cheers Spikey, have been off the forums for a while :(
