FAO Lexicon MC8/12 owners
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by stephenbarnes, Jul 17, 2015.
  1. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
    I have got 13 encoder/volume control pots available soon, these have been custom made. Volume controls on Lexicon seem to be unreliable, my MC-1 also had similar problem. When you increase (with the physical volume dial) up, it might stutter and decrease volume. And vice versa.
    For Lexicon MC-8, and possibly MC-12, also JBL versions I guess.
  2. Wull
    Wull
    May 19, 2009
    3,892
    lake district
    +621
    I found with my MC-1 if I switched if off then spun the volume dial either way it cleared this problem for a while.
  3. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
    It came to the point I removed the cable to the MC-1 volume board, as it sometimes moved on it's own.
    Seems they use low grade part. Hardly use the front volume dial as well.
    I'm getting 15 made but I'm keeping a couple
  4. Wull
    Wull
    May 19, 2009
    3,892
    lake district
    +621
    Pretty poor considering how much the Lexicon's where back in the day.
  5. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
    You should see what PSU is inside the MC-1. Been repaired twice now.
  6. Wull
    Wull
    May 19, 2009
    3,892
    lake district
    +621
    Yep, I had to replace mine.
