FAO: JPN PSP Owners - Network update v1.50 available
Discussion in 'Playstation Forums' started by wallisj, Mar 24, 2005.
  1. wallisj
    wallisj
    Dec 14, 2004
    251
    Nottingham
    +11
    Everyone with Japanese PSP can now use network update to get the first firmware release from sony....basically it updates a few languages and also the ability to resume movie playback from sleep (normally resets)
    Not anything mega but hey...its there....
    Its a 13Mb download!
  2. jenic
    jenic
    Dec 10, 2004
    2,907
    83
    +180
    It say's it needs a memory stick.
    Will the update only operate when the memory stick is in?
  3. uczmeg
    uczmeg
    May 18, 2003
    3,433
    71
    Nottingham
    +52
    I don't believe this will be the case.
    It just needs somewhere to store it so it can install it.
    Downloading mine now.
    Marc
  4. uczmeg
    uczmeg
    May 18, 2003
    3,433
    71
    Nottingham
    +52
    It downloads the memory stick and then you can choose to install it now or later. Or presumably use that memory stick on someone else's PSP with no network connection.
  5. jenic
    jenic
    Dec 10, 2004
    2,907
    83
    +180
    I just recieved my memory stick through the post and it is how you said!
    Took me a while to find out how to make the video folder but thanks to ballofodd, i got there in the end!
  6. dvdchild
    dvdchild
    Aug 10, 2004
    5,690
    2
    +441
    Could you post a link on where this can be obtained?
    DVDCHILD
  7. nero0410
    nero0410
    Jan 5, 2004
    12,095
    southwest
    +4,639
    :lease: We would be most greatful :)
    tris
  8. jenic
    jenic
    Dec 10, 2004
    2,907
    83
    +180
  9. uczmeg
    uczmeg
    May 18, 2003
    3,433
    71
    Nottingham
    +52
    You do it through your PSP. Or use the link in the next post...
  10. wallisj
    wallisj
    Dec 14, 2004
    251
    Nottingham
    +11
    http://www.psphacks.net/cgi-bin/
    this website checks for updates and provides a direct download link from the Sony update site.
    Put it in the
    PSP\Games\UPDATE folder....then you can just run it whenever you want.
  11. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    35,074
    Bristol
    +8,421
    Is this and official update, just want to make sure as I heard about the last PSP update that was released on the net and it damaged your PSP.
    Also, after I have downloaded the file, do I just create the new folder and move the file across manually is there an automatic function?
  12. uczmeg
    uczmeg
    May 18, 2003
    3,433
    71
    Nottingham
    +52
    Your PSP won't pickup a non official update. So the one got through that is official.
    I haven't download the one above, but assume it is just linking to the official Sony one.
  13. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    35,074
    Bristol
    +8,421
    When I saw the update listed on the Official Sony PSP website I decided it was ok so installed it and everything seems to be working fine.
    One thing I noticed that I thought was a good idea is that it wont allow you to install the firmware update unless you have the PSP charging, they want to make sure you have enough power to complete the update otherwise if the PSP shutdown half way through it would be dead.
  14. wallisj
    wallisj
    Dec 14, 2004
    251
    Nottingham
    +11
    the page i posted is basically a web-based checker for updates, the link provided is the same one used by the PSP directly....i have used the file downloaded from that link personally on my PSP and it worked perfectly...i wouldn't post something i didn't already use.
  15. KezzaBezza25
    KezzaBezza25
    Feb 2, 2005
    32
    has anyone installed it?
  16. jenic
    jenic
    Dec 10, 2004
    2,907
    83
    +180
    yep, i have
  17. KezzaBezza25
    KezzaBezza25
    Feb 2, 2005
    32
  18. jenic
    jenic
    Dec 10, 2004
    2,907
    83
    +180
    yep, i have
  19. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    35,074
    Bristol
    +8,421
    Me too, takes about 2/3 mins to install then it restarts. The only way I can tell it has updated is to look in System Settings where it states v1.5
  20. dvdchild
    dvdchild
    Aug 10, 2004
    5,690
    2
    +441
    can somone please advise how you use this download. I got a eboot.pbp file and not sure what to do with it next.
    dvdchild
  21. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    35,074
    Bristol
    +8,421
    Its pretty straight forward, just hook up your PSP, activate the USB connection and create a folder called UPDATE in the Game directory so it looks like this...PSP\Games\UPDATE
    Then just transfer the file into the new directory, hook up the AC charger, select the Memory Card under the Game section and start the update.
  22. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    Just did it yesterday. wi fi seems fast on the PSP! that 13mb file didnt take long to download! how fast do u guys reccon it will be for gaming?
  23. aligebes
    aligebes
    Jan 2, 2004
    233
    Edinburgh, Scotland
    +3
    Just did the update myself, no problems here either.
  24. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,343
    2
    167
    The Wheldon Road end!
    +8,369
    Got my Jap PSP today and did the update after it picked up my router straight away :clap: . Why can't all technology be like the PSP, it's just so user friendly!
    My download was also very quick and online gaming should work a treat! :thumbsup:
  25. tom_g
    tom_g
    Feb 23, 2005
    148
    the directions to do this are very simple and yet i cannot get it to work!
    (i'm doing it via usb)
    tried re-downloading the file and putting it in these places-
    e/psp/games/update
    e/psp/games - when in here it comes up as corrupted data.....
    e/psp/savedata/games/update
    e/psp/savedata/update
    e/games/update
    e/games
    i think that's all variables i tried
    battery is charged and ac powered
    any ideas?
  26. aligebes
    aligebes
    Jan 2, 2004
    233
    Edinburgh, Scotland
    +3
    Have you formatted the memory stick? you must do this on the PSP 1st, do not have the PSP connected to your PC and do not use the PC to format the stick.
    Once this is done, put it in the 1st folder you mention, you may need to create the folder inside the psp/games directory. USE CAPITAL LETTERS to name the folder.
    Then disconnect from your PC, plug into the mains and then select the memory stick via the game option and click to start the update. Your PSP will reboot and you can then go into the System settings, and select System info and it should tell you that you are now using version 1.50.
    Hope this helps, but make sure you format the memory stick using your PSP 1st
  27. tom_g
    tom_g
    Feb 23, 2005
    148
    thanks for that, you were spot on (i figured it out and did it myself 1st tho!)
    it's because i was using the duo stick out of my camera.
    a quick format and it worked fine. loving the new update.
    cheers
    T
  28. aligebes
    aligebes
    Jan 2, 2004
    233
    Edinburgh, Scotland
    +3
    Glad to be of assistance!!
