FAO hornydragon/MAW
Discussion in 'Plasma TVs Forum' started by NWhiteley, Jul 22, 2005.
  1. NWhiteley
    NWhiteley
    May 29, 2005
    2,038
    Westhoughton
    +96
    hornydragon/MAW...... i need some help
    i am considering the current offer by MAW for the PWD7. i was looking at the HD panel from Samsung, but have been having second thoughts. anyway if i was to order the PWD7 package from MAW what else would i need?
    current set up....
    toshiba sd210e DVD, (more than willing to upgrade)
    denon avr1802 receiver (again willing to upgrade)
    wharfedale/eltax 5.1 speakers..(will do for now)
    samsung smt2100c ntl digibox.... only got scart output
    sony ps2
    pc with twin dvi output
    any input greatfully accepted
    is the PWD7 the correct screen to for, with HD only a few months away?
    its certainly within budget, i have around £1500 to £1600 to spend
    or is it worth waiting for the series 8 panels to come out, even though they will be way over my budget?
    cheers....neil
  2. chris
    chris
    Nov 20, 2000
    1,226
    romney marsh, kent, uk
    +28
    Are you going to be useing HD when it comes out.
    From what i've read, it's only a few demo trailers on PC and about 2 porno DVD's at the moment, although i could be wrong.
    Also heard that the Sky HD channels will prob only be sport channels and 1 movie channel.
    It will prob be a good 6 months to a year before there are loads of HD DVD's around.
    I was going to go for the new Samsung SD model, untill i got a good price on my panny 435 and i have always liked the look of the panny plasmas.
    But i doubt i will be watching anythink HD for a good couple of years.
    I dont intend changing my DVD players for a while and there is no way i'm buying my entire dvd collection again, just to get HD and there is no way i'm giving Sky another £400, they get enough of my money as it is.....i'll wait untill they get more channel running and drop the price.
    So there you go.......just my take on it.
    If you need HD buy the Sammy, if you can do with out it and you dont mind upgradeing your TV in a couple of years time then go for the PWD7.
    That prob help to add to the confusion your going through.....i was the same 3 days ago.. :suicide:
  3. NWhiteley
    NWhiteley
    May 29, 2005
    2,038
    Westhoughton
    +96
    thanks chris. i think i may take up this offer from MAW. even if i only keep it for 12 months its still a good deal
  4. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
  5. docnaz
    docnaz
    Jul 17, 2005
    119
    16
    London
    Hi Neil
    entirely understand your quandry. I am going thru the same thiught processes. One day the 2.5k for the Panny seem the only option and other days I look at the price of the PE50's or less and think that would be absolutely fine for 2 to 3 yrs. I think Sky HD will very pricey for couple years minimum. What I really wanted to ask was whether you have seen an HD demo. Saw one in John Lewis on the 42Pv500 and the PQ was awesome. I think that spoilt my thought processes and steered me towards HD ready.
    Good hunting
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    what you will need in addition to the package from MAW is a DVi board for PC, a new AV reciver with component switching DVD with component out a PS2 component lead (check serial number as very early models have some issues with component) then i would say a JS RGB>YUV converter for TV cable box then feed DVD, TV and PS to AMP Denon 2105 etc is ideal (perhaps new Onkyo) and away you go
  7. NWhiteley
    NWhiteley
    May 29, 2005
    2,038
    Westhoughton
    +96
    hi hornydragon
    is this what you are suggesting?
    ps2 via component to av amp
    dvd via component to av amp
    ntl connected to JS RGB>YUV
    JS RGB>YUV via component to av amp
    av amp via component to pwd7
    pc connected to optional dvi board in pwd7
  8. NWhiteley
    NWhiteley
    May 29, 2005
    2,038
    Westhoughton
    +96
    Hi mep
    cheers for the pic, does the JS improve the picture quality on sky a lot or does it depend on the chanel?
  9. NWhiteley
    NWhiteley
    May 29, 2005
    2,038
    Westhoughton
    +96
    i have seen both the sammy HD and the pv500 showing the usual HD demo's in comet, and i was very impressed, but im not sure if the extra cost is justified. the current HD screens all seem to have some niggling faults, so im seriously considering waiting for next generation of screens to come out
  10. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    It does it improve it a lot...you will still get some bad channels with low bit rate but many channels are near dvd quality
  11. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    Chris, the 435 isn't a Panny mate!
  12. NWhiteley
    NWhiteley
    May 29, 2005
    2,038
    Westhoughton
    +96
    mep, hd doesnt seem to be on line tonite, so does my understanding in post #7 seem to be accurate?
  13. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    yep, spot on matey
  14. NWhiteley
    NWhiteley
    May 29, 2005
    2,038
    Westhoughton
    +96
    i know this will be in the wrong section but can you recommend a decent component swiching av receiver and a dvd with component output. no more than £300 for both though
  15. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    doubt it at that price. my azur is £250 and i cant pass a prog scan signal through it :( it just tears the image. otherwise its cracking!!! js tech do a component switcher.
    ps well done mep!
  16. NWhiteley
    NWhiteley
    May 29, 2005
    2,038
    Westhoughton
    +96
    what sort of money will i be looking at?
  17. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
  18. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    but it will only switch 2 inputs i think...and he has 3
  19. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    oh right didnt read the first bit about what connections, best get 2 then! a yam 657 is probably ok for it, but i think that only has 2 component in, 1 out
  20. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
  21. NWhiteley
    NWhiteley
    May 29, 2005
    2,038
    Westhoughton
    +96
    thanks for the replies... i think that i will have to throw a bit money at it :smashin:
  22. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    yes, you don't need to go mad but at the same time don't do it 'on the cheap'
  23. NWhiteley
    NWhiteley
    May 29, 2005
    2,038
    Westhoughton
    +96
  24. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    there is, vcr1/vcr2/dvd/tv. i believe these are pairable with the components. i.e. in a menu you set which video goes with which audio.
  25. NWhiteley
    NWhiteley
    May 29, 2005
    2,038
    Westhoughton
    +96
    aahh so that what happens. cheers chedmaster
  26. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    look over on the left of the pic of the rear, it has a coax and three optical inputs for sound
  27. NWhiteley
    NWhiteley
    May 29, 2005
    2,038
    Westhoughton
    +96
    will these optical inputs be directly linked to the component inputs or do they have to assigned?
  28. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Spot on matey
  29. NWhiteley
    NWhiteley
    May 29, 2005
    2,038
    Westhoughton
    +96
    thanks for the advice HD. i think i will be purchasing a PWD7 this week (i get paid on the 28th)
  30. clarky78
    clarky78
    Nov 8, 2004
    1,845
    Helsinki, Finland
    +40
    Just bought one of these today, the picture from components crap, needless to say i'm not keeping it!
