FAO Crustloafer
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Nik555, Dec 30, 2006.
Tags:
  1. Nik555
    Nik555
    Jan 15, 2005
    1,542
    63
    Bebington, Wirral
    +111
    Hi mate,
    A while ago you helped me out on what cables I should be using for my new system. Anyway you said I should connect my DV137 to my AVR350 using three pairs of Black Rhodium Rythem Analogue cables. Well I cant find them anywhere, I can see some Stereo audio Phono to Phono ones, are these the ones? Do you know where I could purchase some from.
    Any help much apreciated.
    Cheers Nik
  2. Dankeech
    Dankeech
    Feb 1, 2005
    3,637
    Stevenage, Herts
    +299
    Hi Nik555, saw this post and thought I might be able to help anyway.
    Not sure if you're googling what you've tyoed as a search, but Rhythm is spelt differently to how you've typed on this post. Not sure what method you're using to try to track a cable down, so just thought I'd mention.
    Here's a froogle search link:
    http://froogle.google.co.uk/froogle...G=Google+Search&ie=UTF-8&oe=UTF-8&sa=N&tab=wf
    Also, I tend to use Sevenoaks for branded cables myself, so www.ssav.com would be a good place to start if looking for cables from a proper retailer.
    Hope this helps.
    Dan.
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,577
    Edinburgh
    +1,269
    Those are the ones I meant.
    I don't know about other Sevenoaks stores but we certainly sell them where I work.
