FAO all Seal IV Dvd-a owners
Discussion in 'Blu-ray & DVD Players & Recorders' started by rozzar, Jun 26, 2004.
  1. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    can you get the menu up on your dvd-a player? i'm on my 2nd copy from amazon now.
    it plays back (the conventional Dolby and DTS layers) on my old Yamaha DVDS520 dvd player fine, but the Pioneer DV747 really will not bring up the menu for the DVD-a part that i bought it for
    after physically inspecting the discs, theres a kind of impressed water mark around the inner half of 50% of the disc where they were made. Both copies were like this
    could this be the problem (in which case, presumably a faulty batch)
  2. Simon6776
    Simon6776
    Jan 7, 2003
    2,258
    West Sussex, U.K.
    +33
    I had the same problem with some of my DVD-As on my Pioneer DV656-A. What I have to do is go into the Set Up Menus > Initial Settings > Options > DVD Playback Mode, and change it from DVD-Audio to DVD-Video, which then gives access to the other menus on the DVD-A, to enable you to find and play the DTS, or Dolby Digital soundtracks. Bloody pain in the arse, but I don't know another way round it!
  3. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    thanks Simon
    i can play the dts and DD parts fine. i just select group 3 or 4 respectively on the dvd player. even when its playing a dts or DD track on the disc, and i try to get into the disc menu, it just freezes. i have no dvd playback option on the 747- the 656 is a slightly later player iirc
    contemplating returning this one to amazon too (yawn) and buying it locally to try and locate one without 'water marks'
  4. sacd
    sacd
    Feb 19, 2004
    297
    Cardiff
    did you ever get this sorted out? I have the DV747 and was just about to get the seal dvd-a.
  5. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,628
    2
    In a secret location with Jennifer Lawrence
    +9,349
    Moved to DVD players forum
