fans on my dell c800
Discussion in 'Desktop & Laptop Computers Forum' started by thelostone, May 4, 2007.
  1. thelostone
    thelostone
    Apr 25, 2005
    247
    nottingham
    +6
    Hi everyone i have a dell latitude c800 laptop and on the back it has two fans but what i have noticed is only one of the fans seem to work.Dose anyone no if they are both supposed to come on at the same time or dose one come on when it gets hotter?I am a little worried as i don`t want my laptop to over heat
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,474
    2
    +1,366
    Do not know how many fans should or should not come on but in your Bios or possibly a monitoring program in Windows the PC should shutdown before it over heats.
  3. thelostone
    thelostone
    Apr 25, 2005
    247
    nottingham
    +6
    Thanks mate that the other fan is controled by the temp so i should be ok
  4. skippyonspeed
    skippyonspeed
    If they are the same type try swapping them briefly to see if you get the same effect, otherwise that one might be "windless"
  5. thelostone
    thelostone
    Apr 25, 2005
    247
    nottingham
    +6
    Thanks mate it seems to be working ok so i am a bit weary of taking it to bits to change it while its working
