fanless psu
Discussion in 'Computer Components' started by homethx, Jul 31, 2003.
  1. homethx
    homethx
    Feb 24, 2002
    728
    +78
    Have you seen this power supply from Kustom pc expensive though :eek:
  2. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    From a reveiw here http://www.silentpcreview.com/modul...ns&file=index&req=viewarticle&artid=90&page=1
    The proSilence PCS-350W fanless PSU's strengths:
    Heavy build quality, with massive heatsinks
    Excellent stability
    Very good voltage regulation
    Good self-cooling within rated power limits
    Truly silent: 0 dBA!
    The proSilence PCS-350W fanless PSU's weaknesses:
    Output power could be higher
    Misleading 350W in model designation
    Short ATX and 12V cables to motherboard
    Price
    The proSilence PCS-350W is a solid, perfectly viable fanless PSU well-suited for use in the vast majority of quiet desktop PCs. Its use does not obviate the need for fans elsewhere in the PC. A fan for case cooling is probably necessary to evacuate the heat generated by the CPU, hard drive, RAM and other components. Most systems will also require a fan for CPU cooling. Regardless, the proSilence PCS-350W deserves a strong recommendation for being the first fanless drop-in substitute for a ATX12V PSU.
  3. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    Only 170W ooch!, I didn't think the voltage regulation figures where that great. I would expect +- 1% in most cases.
  4. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    It was the fact that the reveiw suggested that you would still need a case fan, might as well stick with a decent single fan psu instead, cheaper and more efficent at delivering power.
  5. Rob.Screene
    Rob.Screene
    Sep 29, 2001
    1,124
    Berks, England
    +45
    I bough one of the pyramid case fan controllers from quietpc to try in an Athlon 2400+ desktop. It seems to works very well. Nice to have it idle when the machine is idling and then respond when the case is crunching numbers, case temp seems permanently 30-32 degrees, Athlon 40-54 degrees.
    Perhaps this might work nicely with the above psu as it would keep the mainboard more temperature stable.
    Still, really expensive compared to the wonderful Zalman 300w.
    regards,
    Rob.
  6. Stefan
    Stefan
    I was going to get one of these for free if I could find a Danish guy a gold DIGN HCPC case, but I couldnt' find the one he wanted. It was a 550W one too! :rolleyes:
