Fanless agp, for a shuttle box
Discussion in 'Desktop & Laptop Computers Forum' started by sean.pittaway, Sep 1, 2005.
  1. sean.pittaway
    sean.pittaway
    Apr 23, 2004
    83
    Title says it all really...
    Can anyone save me some time by pointing me in the direction of any fanless agp graphics cards that will fit in a shuttle box (i will change the case eventually, but for now it has to stay)?
    Cheers for any replies, Sean.
  2. DaveP
    DaveP
    It all depends on how much you wish to spend!
    It starts at about £25 for an ATI 9200 and goes up to about £200 and more for the higher spec cards.
    Do you need dual monitor support? Will you be playing demanding games?
    Dave
  3. iamlofi
    iamlofi
    Jul 1, 2005
    81
    to add another post on here im also looking for a sub £100 AGP graphics card which is fanless for a shuttle. Mainly for HTPC but also wouldent mind playing games but not a priority!
  4. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    If you can go a little over the ton, have a look at Gigabytes fanless 6600GT. 130 quid I think.
  5. Skunkpipe
    Skunkpipe
    Does a fanless 6600GT physically fit in a shuttle?
    Radeon 9600 fanless has a nice small heatsink if not
  6. Rambles
    Rambles
    Jul 14, 2004
    8,318
    UK
    +1,288
    It just fits in to my SN41G2V2 but can't use the PCI slot now.
  7. Taylorg
    Taylorg
    Dec 6, 2004
    89
    I have a question Will a Radeon 9700 Pro with a fan work in a shuttle XPC? I have a ST64G4 with the ATI chipset that I want to use as a HTPC. I am using the onboard 9100IGP at the moment but I need more horsepower for HD playback. I have access to a Radeon 9700 Pro from ebay.
    Grant
  8. sean.pittaway
    sean.pittaway
    Apr 23, 2004
    83
    Cheers for the replies...
    Price wise, i was after £100-£150
    And i need to keep the pci slot available, i have a tv card in there
  9. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    It will fit and work quite well. However do not pay too much for that 9700. It is already 3 generations old and you can pick up more capable cards for not a huge amount of cash. By that I mean more poweful and cooler running.
  10. tartan_guru
    tartan_guru
    Nov 17, 2003
    154
    London
    +17
    I've just swapped out the GFX5200 that I had in my shuttle box for a 6200 (around £50 from scan). The 5200 was struggling with HD stuff, but the 6200 copes with 1080i without any problems. Its fanless and low-profile so it fits in a shuttle with no problems
  11. sean.pittaway
    sean.pittaway
    Apr 23, 2004
    83
    have you got a link to the card you got (really busy at the moment) and was it agp?
  12. tartan_guru
    tartan_guru
    Nov 17, 2003
    154
    London
    +17
  13. Taylorg
    Taylorg
    Dec 6, 2004
    89
    Well the 9700 Pro was causing too much heat in my Shuttle so I've ordered a 6200.
    Grant
  14. originalbadboy
    originalbadboy
    Mar 27, 2003
    238
    +3
    For a year or so I used a Sapphire 9600pro fanless card, and worked perfectly fine in my shuttle(s).
    I have now upgraded to a Sapphire X700pro AGP card, which does have a fan, and at first I was worried it might sound like a aircraft taking off, but it doesnt make any noise at all (even to the point where I have taken the lid off to make sure its still working!).
    Its perfectly acceptable for gaming (not the best, but good enough), and more importantly it is quiet, as my games shuttle doubles up as my DVD machine as well.
    I picked up the card for around 120 for the 256MB version, from ebuyer.
  15. davemacrae
    davemacrae
    Aug 24, 2005
    13
    The Gigabyte 6600 fanless will fit in the PCI slot of a Shuttle. However, the tuner card I had in the PCI slot had to be removed (now swapped for a USB version).
    Also, the heat pipe that goes between the front and back heat sinks makes it a very tight fit when installing. You sort of have to bend the card a bit to make it fit.
    Once it's in place, everything was fine.
    Dave
