Fan noise....
Discussion in 'Projectors, Screens & Video Processors' started by dc007, Feb 10, 2003.
  1. dc007
    dc007
    Nov 22, 2000
    1,091
    48
    London, U.K.
    +47
    How bad is it with your projector ?
    Does it bug you ?
    How do you deal with it ?
    Of the projectors you've owned/demo'ed, what are the best with regards to noise ? The worst ?
    Is LCD quiter that DLP ?
    I've owned a SIMHT200 and could just about deal with it. HT200DMF demo was a little noisier. HT300 was unacceptably loud. Yamaha DLP was very quiet, but the rainbows were a killer...
    How do the Runco DLP's weigh up from a noise perspective ?
  2. Branxx
    Branxx
    Nov 1, 2000
    801
    London, UK
    I have JVC D-ILA that is very loud. It is mounted on the ceiling with the hush-box that insulates noise and well as heat coming out of it.
    When I selected my projector 3yr ago the picture quality was the main criteria, so I got this other two side effects that had to be dealt with.
    Apart from building hush-box you can examine a possibility of placing the projector in an adjoining room and create a small opening on the wall as a projection window. The is the simplest way of removing the noise (that is apart of buying a quiet projector in the first place.
  3. Erik_Visual
    Erik_Visual
    All depends really, for what purpose you are using the projector. But if you are going to watch a movie or something similar louder than 32dB is very annoying.
