Fan noise on Toshiba and Pioneer DVD/HDD Recorders
Discussion in 'Blu-ray & DVD Players & Recorders' started by laser, Aug 1, 2004.
  1. laser
    laser
    Aug 1, 2004
    987
    Hartlepool
    +46
    I've narrowed my purchase for a new DVD recorder to a Pioneer DVR-420S or the Toshiba RD-XS32 mainly due to current pricing being around £400 for the players. However I've read a posting stating the fan noise on the 420S is pretty bad and wondered if this was indicitive of most DVD/HDD players or specific to the Pioneer range or the 420S.
    The review of the DVR-520S and the RD-XS32 in this months HCCO magazine made no mention of fan noise which makes me wonder in the DVR-420S uses a cheaper fan than the other models in the range.
    Doe the Toshiba RD-XS32 have a fan?
    I've considered the 520S but it's a bit too expensive and I don't really need the i-link capability, hence the 420S fits my needs. Although at the £400 price range the Toshiba has it as a bonus, in my particular case.
    Any comments on fan noise...
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,775
    Warwick
    +2,675
    Yes it does. Fan noise of that machine is discussed in the Toshiba RDXS32 Review Thread:
    http://www.avforums.com/frame.html?http://www.avforums.com/forums/showthread.php?t=137168
    If noise is a real concern to you you may want to see Bluesfan's comments on the Pioneer 420 as well:
    http://www.avforums.com/frame.html?http://www.avforums.com/forums/showthread.php?t=140529
    Have you consider the Panasonic E85 as well? Also in that rough price bracket (cheapest £420 on Pricerunner). Overall both the Panasonic and Toshiba are superior to the Pioneer in many respects.
    The Toshiba is probably the best of the bunch: extensive DVD authoring options, iLink, progressive scan/component out and arguably the best DVD playback of any DVD recorder. Certainly most of the new buyers here have gone for the Toshiba...
    The Panasonic has DVD-Audio support (2 channel) and can record upto 3hrs full resolution (as oppsoed to 2hrs 20mins for the Tosh/Pioneer).
  3. laser
    laser
    Aug 1, 2004
    987
    Hartlepool
    +46
    Thanks for the thread links.
    The Toshiba it is then :)
  4. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    welcome to the club sir :clap:
    got mine (still in transit) from RGBdirect for 409 (multiregion)
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,775
    Warwick
    +2,675
    I don't think you'll be disappointed.
  6. cyber_who
    cyber_who
    Jul 22, 2004
    77
    Ashford
    +5
    Good choice on the Toshiba, it is a very good machine.
    As for noise, mine is in our bedroom and my wife has not yet complained about the noise and she is paranoid about noise at night.
    I can only hear it if I get right up close to it.
  7. xyznicko
    xyznicko
    Its pot luck you can get some noisy ones, you certainly couldn't put my Toshiba in the bedroom.
    To be honest I don't know where these guys are coming from that say the Toshiba is quiet, I've had several hard disk devices including the Toshiba(Tivo, Skyplus) and I have yet to get one that is anywhere near what you could call quiet.
  8. Clovisguy
    Clovisguy
    I own a Pioneer 420H-S and it is very quiet. I was aware of the noise problem complained about at this forum when I purchased it. They became available here in the U.S. last month. They include a component out here. I love it and it is easy to use.
  9. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    Xyznicko, its down to the individual. I work in an office full of PCs, I bet ive become deaf to PC fan noise, so my perception is that the Tosh is inaudiable.
