Fan for p3-500
Discussion in 'Desktop & Laptop Computers Forum' started by rhinoman, Feb 9, 2003.
  1. rhinoman
    rhinoman
    Oct 31, 2000
    2,603
    71
    Herne Bay, Kent
    +33
    The one in an old machine pf my parents is getting really noisy, any ideas where I can get a new replacement?
  2. nutcase_1uk
    nutcase_1uk
    Apr 15, 2002
    479
    Essex, unfortunately
    +3
    Quite often if you peel off the label on the centre hub of the fan, and put a couple of drops of 3-in1 oil or similar, and put the label back, the fan will return to its former quietness. Probably won't last as long again as a new fan, but certianly cheaper :)
    Otherwise, if it's a socket 370 it looks like this one will do:
    http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=35743
    and it's dirt cheap :)
  3. rhinoman
    rhinoman
    Oct 31, 2000
    2,603
    71
    Herne Bay, Kent
    +33
    Thanks nutcase, unfortunatly I think its worse than that as there is a brown dust residue all aorund it maybe where a bearings breaking up.
    Unfortunatly its not a socket 370, its an older slot type.
  4. nutcase_1uk
    nutcase_1uk
    Apr 15, 2002
    479
    +3
  5. rhinoman
    rhinoman
    Oct 31, 2000
    2,603
    71
    Herne Bay, Kent
    +33
    Hadn't though of just changing the fan, though I'd have to replace the whole HSF:blush: Looks like any 50mm fan with a 3pin MB header will do.
    Cheers Nutcase
