Hi All
Ive just recently splashed out on a new Panasonic 50 Plasma (VT30) Ive mounted it on a slimline Cantilever bracket purchased from M-Form. The TV and bracket are situation on the side wall of my chimney breast. This wall measure about 1400mm wide and the TV is 1200mm wide. Ive got a Alpherson AV cabinet sitting on the floor directly below the TV which is also 1200mm.
My question is that Ive been reading everyones false wall posts with interest and would like something similar.. Most have kept a clearance around the MDF and wall edge to aid backlighting etc, but looking at my situation its really doesnt look possible as Ive only got about 100mm gap between the side of my TV and edge of the chimney wall and sliding patio on the other side...
Would a narrower smaller false wall say 1000mm wall look really random and silly behind my TV (1200mm) so it would be wider by 100mm each side.. The original idea when I was planning it was based on a 42 TV which was recessed into the false wall, but I opted for a 50 so its all off sync now.. Ive included a quick sketch to show what I mean.. Its not to scale and I guess looking at it, the false wall is probably going to look a little more wider then actually shown in my drawing.
Opinions much appreciated.
Jag
Jag
