5chulzy
Hi ive been giving the all clear by the misses to start doin some work in the living room. We had an old back boiler removed last year and was left with a brick fireplace surround that is really horrible (pic 1).
The plan is to remove all the brick surrond so im left with just the chimney breast (pic 2) and then build a stud wall wall around it (pic 3) out of 4x2 or 3x2 timber and then board it with 12mm plasterboard (pic 4).
Ill make two recesses for a new panny p50g10 and an electric fire so they are sunken into the wall. The stud wall will sit 30mm off the existing wall so I can run cables behind the wall and up to the tv, and the tv will be fixed to the existing chimney wall so the distance from existing wall to front of stud wall is enough for the tv to be sunken in.
All the cables will run out of the right hand side where I will have Sky+ HD, PS3, Xbox360, Wii and DVD player connected.
Ive got to move a few electrical sockets about but am I right in thinking its as straight forward as
1. remove bricks
2. build stud wall
3. run cables behind studs
3. plasterboard
4. move electrical points
5. plaster and make good.
Im pretty good and diy and building stuff so i will do it all my self the only thing I will get someone to do is the plastering (got a friend that I can ask for mates rates)
Will Ill be able to use 3x2 timber or would it be best to use 4x2? (pic 5) and does the design look suitable?
1. remove bricks
2. build stud wall
3. plasterboard
