Question fake phone charger ?
Discussion in 'Mobile Phones Forum' started by R0bertSK, Apr 6, 2016.
Tags:
  1. R0bertSK
    R0bertSK
    Apr 6, 2016
    2
    3
    Slovakia
  2. coolgadgetkid
    coolgadgetkid
    Apr 13, 2016
    Birmingham
    Hi there.
    I have been reading up on these fake chargers and batteries after the hoverboard incidents, and I must say that this particular item is not the original however it is safe enough to use. I had a look at the circuit board and the capacitors and the resistors look fine and this indicates to me that the likelihood of something like the exploding or causing any other issue is incredibly small.
  3. outoftheknow
    outoftheknow
    Nov 1, 2012
    3,662
    Canberra, Australia
    +1,265
    You looked at this item? I don't believe you to be honest. And again I suggest you don't ask for ratings - it's against the rules.
    Edit - to be clear I am doubting looking at pictures of internals is conclusive unless you have opened genuine chargers of the same make and model. If you have for this one then fair enough.
  4. R0bertSK
    R0bertSK
    Apr 6, 2016
    2
    3
    Slovakia
    if it is fake then for me it is not safe...
