Fair price for aerial installation?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Yousanem, May 20, 2005.
  1. Yousanem
    Yousanem
    Had enough of NTL so planning to go the Freeview route. Unfortunately, where I live is on the fringe of the reception area. Called up the only nearby CAI installer and got quoted £360 (inc VAT) for a standard 1 aerial (DMX10A), omni FM, amplifier, chimney mount, 10M cable and sundries. Don't want to mess around if this is reasonable, but is it?
  2. Blu Ray
    Blu Ray
    Jun 14, 2004
    495
    Chorley, Lancs
    +12
    Seems a bit steep. I paid £65 but did not include amplifier or mount.
  3. Bernard Barnett
    Bernard Barnett
    May 16, 2002
    671
    Norfolk
    +5
    Much too steep even for a fringe area assuming you're not multi-room cabling. You must live in a very remote part of the world if there's only one CAI installer within range. Many installers will travel upwards of 30 miles so I suggest you broaden the search. By the way if anyone offers you a "digital" aerial for Freeview you should run a mile from them - there's no such thing.
  4. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,827
    Galactica C.I.C.
    +272
    Paid £100 for mine including VAT.
    This was for arieal, cableing, fitting, plus two year warranty and to make sure that everything was tunned in ok.
