Faint discolouration FS76
Discussion in 'General TV Discussions Forum' started by Tommo24, Mar 31, 2003.
  1. Tommo24
    Tommo24
    I am very happy with my FS76 but it does have deflection problems across the top inch of the screen, mainly top left corner.
    Also in this corner I have noticed a very slight discolouration (faint blue/purple/green) most noticeable when viewing a white image.
    What is this discolouration called and how can I get rid of it? I have a House of Fraser 5 year warranty so should I just call an engineer out?
    I am not too concerned about the deflection but I assume the only way to correct this is to enter the service menu.
    Thanks for any advice offered.
    Tom
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    The discolouration is known as a "purity error" and is caused by a magnetic field (either from a local source or the earth!) it can usually be cured with degaussing. To initiate a full degauss, switch the TV of at the switch (not the remote) at night, when switched on in the morning a "thunk" will be heard which is the degaussing circuit doing its work. If this fails after 2/3 attempts it's best to call an engineer to carry out a "manual degauss" using a "degaussing wand".
    The geometry error can only be solved with entry to the service menu.
  3. WSH
    WSH
    Apr 13, 2002
    997
    28
    +39
    Mine has exactly the same stain in the top left corner. Looks like it may be the internal speaker since we both have it.
  4. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    On my FX66 I have this stain on the bottom right, although I only notice it when I look for it i.e. it ain't that bad.
  5. SimonO
    SimonO
    Nov 4, 2002
    3,193
    71
    Hertfordshire
    +64
    Mine is the same... Very slight in top corners... I'd also put it down to the internal speakers... I had a similar problem with a previous FQ75 which had very poor magnetic shielding under the tube... I couldn't put anything on the shelves under the set..!
    If you get an engineer out, they can fix compensating magnets to the tube, but in my experience this puts out the geometry... But as most sets have poor geometry in the top corners then it may be worth a try...
    My advice is always buy a CRT TV with a good warranty from a reputable dealer, that way you can at least change it if you're not happy... I'd always pay the extra..!
