Failed Recordings
JamesU2002
For the past two days when we have had our recordings all fail.
E4 Big Brother (9pm) has failed twice and Waterloo Road also failed. Both were due to No Signal. Even though everything is working fine.
Any ideas what the problem is?
James
F
Fatwaz
could be a few things most notably the HDD but try a planner rebuild
To perform a planner rebuild:
1) Press the 'Services' button to access the "Services" menu
2) Press the number '4' to access the "System Setup" menu
3) Press the number '0' then '1' then press the 'Select' button to access the "Installer Setup" menu(you wont see the screen change till you press select)
4) Press the number '7' to access the "Planner Rebuild" menu
5) Press the 'Select' button to start the planner rebuild.
leave it to "housekeeping" and when its finished and rebooted let it settle down and try em again
