Failed recording of Smallville finale
Discussion in 'Satellite TV, Sky TV & FreeSat' started by cebs_uk, Jun 9, 2004.
  1. cebs_uk
    cebs_uk
    Jan 25, 2004
    2,537
    Manchester
    +406
    I just tried to view last weeks Smallville and got an error that I have never seen before.
    The information box comes on with a blue background and just stays there with the play light going but no picture ever comes on and the controls won't rewind/forward.
    The recording states it tapes for the correct time and does not say failed, this is typical as I have now missed the repeat at the weekend.
    Does anyone know why this fault occurs and is there any cure ( small hope I know).
    If anyone has the episode on the machine I would be grateful to try and sort out a copy.
    Thanks in advance
    Cebs
  2. Gort
    Gort
    "If anyone has the episode on the machine I would be grateful to try and sort out a copy."
    What do you mean? Don't understand that at all? what machine? yours/mine?
    Might be able to help if you explain it better!
    But I gotta say Smallville was good, had a nasty ending.
    Lexx, Chloe and her father are dead !!! The kent's farm is on fire, Clark's gone to planet Krypo. What a cliffhanger... :(
    Rumours are though that they all return for season four except pete.
