Failed burn on Panasonic
Discussion in 'Blu-ray & DVD Players & Recorders' started by Nelviticus, Oct 30, 2004.
  1. Nelviticus
    Nelviticus
    Jun 21, 2003
    469
    Hitchin
    +68
    Has anyone had a failed DVD burn on a Panasonic recorder? I was just wondering what they're supposed to do because mine (an E95) does something very strange. It immediately resets itself and goes into a longer than normal self-check, then comes up with a message saying that burning failed.
    I'm hoping that this is what it's supposed to do, because otherwise my machine is on the blink!
    I had been using Datawrite Red V2 with no problems. When I ran out of those I switched to Datawrite Red V3 and the first two I have tried have failed as described above. I also tried a BulkPaq Orange Generation 4 and it did the same thing. However I've just tried a RAM disc and it worked fine, so if it is faulty then it's not completely faulty.
    Any idea whether I should be worried? Any reccommendations for blanks that work well with Panasonics would be welcome.
    Regards
    Nelviticus
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
    That sounds fairly normal - sometimes the Recorder will bring up a message saying it has failed to burn and then lets you continue whereas other times it self-checks. I suppose how much it dislikes the media :)
    Personnally I stick to branded media: JVC, TDK, Panasonic, Pioneer, Sony, Verbatim, Maxell, HP etc etc as I find this is always universally compatible and tends to have better longevity prospects. DVD-Rs are so cheap now there isn't much excuse for not using good quality media.
  3. Nelviticus
    Nelviticus
    Jun 21, 2003
    469
    Hitchin
    +68
    Phew! Well thanks for the reply. It's a bit strange that the V3 discs fail yet the V2 ones were fine, but there you go. You're right about branded media too - I'm so used to looking for bargains that I tend to forget that in some cases I'm only saving myself a few pence.
    I'm off to buy some decent blanks!
    Regards
    Nelviticus
  4. Mar©
    Mar©
    Hi,some time ago I bought Bulkpaq DVD-R: these were the absoluterly crap !
    Didn't work with my Plextor PX-708A, not as DVD, not as musicCD, not as data CD, not as Data DVD.....nothing worked !!!
    Now I buy TDK-DVD's or Emtec DVD',s.
    No problems with these.
  5. HMHB
    HMHB
    Nov 11, 2001
    26,424
    Nottinghamshire
    +5,059
    Which brand DVD-RAM would you recommend and where do you get them from ?
  6. sweat100
    sweat100
    I also have the same experience as you. For me, in the past i used some kind of no brand dvd(cyber dvd) and do high speed dub and the player keeps reseting itself. Thought the panny was spoilt. So this time round i used better media based Tayio Yuden dyes. It works very well. For the cheap disc, i think it can only do real time recording or dubbing. The Panny is quite "choosy" about media.
  7. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
    As most DVD-RAM disks are sourced from either Panasonic or Maxell the actual brand you buy isn't such as issue - that said if you go for uncaddied disks though it's worth paying for a branded disk as it will be protectively coated. I personnally use Panasonic disks - which I normally pickup from the Panasonic E-Shop. I also have used DVD And Media for Maxell DVD-RAMs before with no complaints.
