Factory Reset
Discussion in 'TAG McLaren Audio Owners' Forum' started by cj, Oct 31, 2003.
  1. cj
    cj
    Apr 6, 2001
    1,471
    Reading
    +74
    Anyone know how to perform a full "factory reset" on my AV32 DP?
    Thanks,
    Colin
  2. cskates
    cskates
    Jul 5, 2001
    151
    Belfast, UK
    If you ring up the Tag helpdesk 0800 number they'll tell you the procedure straight away.
    But to save time: Hold in the "Digital"+"THX"+">" buttons then switch unit on. You should get a prompt "Press normal to reset", if you press the "normal" button it will reset.
    Since you have a DP you can use the Backup program to save your user settings before the reset.
  3. cj
    cj
    Apr 6, 2001
    1,471
    Reading
    +74
    Ta very much :)
