Factory reset for Panasonic PL range
Discussion in 'Televisions' started by kevb, Apr 6, 2003.
Tags:
  1. kevb
    kevb
    May 16, 2002
    1,099
    41
    About
    +3
    Does anybdy know how to perform a Factory reset for Panasonic PL range. The thing freaked out on me the other day when I turned it on loud popping noise followed by the set turning itself off and then back on again. Now the convergence is screwed up the image now has red, green and blue halos.:( I just wanted to try a full reset before I try and get an engineer in ASAP or ask for a direct replacement.
