factory defaults av192
Discussion in 'TAG McLaren Audio Owners' Forum' started by jbm007, Jan 29, 2005.
  1. jbm007
    jbm007
    Does anyone know the control sequence on the remote to send the AV192 back to factory defaults. A friend of mine wants to try it before sending it back to IAG He gets an ERR message with no additional codes.
  2. Teejoo
    Teejoo
    Apr 24, 2004
    221
    The Netherlands
    +3
    Just do a master reset (= the same as AV32R):
    1. Turn power off
    2. hold down on front panel ‘digital’, ‘thx cinema’ and ‘>’ keys
    3. While holding down the 3 keys switch unit on
    4. On display will be the word "EEPROM"
    5. Now release ‘digital’, ‘thx cinema’ and ‘>’ keys
    6. Press the "normal" button.
    Good luck
