Face plate to face plate Component / Phone style wiring
Discussion in 'Cables & Switches' started by [Slip], May 16, 2005.
  1. [Slip]
    [Slip]
    Jan 28, 2004
    184
    +3
    Hi all,
    Could someone reccomend me some cable and methods of running some component cable form one faceplate to another.
    I'm in the process of rewiring my cellar and have a face plate that does component, Svideo and composite.
    What sort of cable will I need for the component and composite and is it ok to run a 4 - 5m stretch of it?
    Thanks in advance,
    Matt
  2. Warpaint
    Warpaint
    Jul 26, 2003
    589
    28
    Edinburgh
    +61
    Component cable is basically 3 separate runs of 75 ohm coax cable. (same as TV aerial cable)
    Composite is a single length of 75ohm coax cable.
    Use good quality cable like CT100 or similar as a minimum.
    4 - 5 metres is no problem for good quality cable.
  3. [Slip]
    [Slip]
    Jan 28, 2004
    184
    +3
    Thanks for that,
    any recomendations on where to get the cable?
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,041
    The Borders
    +2,518
    [slip]
    You could use a five core 75 ohm Multicore for the YUV + S-Video plus a single run of 75 ohm for the Composite video.
    We most often use and supply VanDamme cables for installations - they have a fair old range to choose from; drop me a PM if you require more info on what's available.
    Best regards
    Joe
  5. Newtech
    Newtech
    I hvae extended my connection between DVD/Video and projecttor to opposite sides of a room, about 7m of cable. I have put in a 3 point component wall socket at each end, however I am now getting a sort of corduroy effect on my projected image. I have used a 6 core cable (a bit like telephone cable) for the connections. Any advice for this amateur!!
