Fablon req.
Discussion in 'Home Cinema Building DIY' started by Taz, Jun 8, 2003.
  1. Taz
    Taz
    Hi guys if anyone is in a DIY store and they have some Black ash Fablon, and are willing to pick it up for me, please let me know.
    All the stores in High Wycombe our out of stock of black ash..they have all colours bar that one.
    Thanks.
    (I will send the £ first if thats an issue)
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    He he!
    Do you need any more money now Taz?
  3. Exeter Man
    Exeter Man
    Taz,
    Going to B&Q tonight. If they have some, i'll buy a roll and let you know.
    Regards
  4. Taz
    Taz
    A Big roll please! 900mm x 2.5m should be around £10.
    Thanks ;)
  5. Gojira
    Gojira
    Jul 13, 2002
    19
    sorry to be really thick, but is fablon the stuff used on chipboard etc to give it a wood effect?
    if so, does it come in beech?:blush:
  6. Taz
    Taz
  7. Gojira
    Gojira
    Jul 13, 2002
    19
    Thanks Taz.
    Is it easy to work with?
    (I am planning to cover a centre speaker to match my new floorstanders)
  8. Taz
    Taz
    Corners can be tricky, but as long as the room and fablon are warm, should have no problems. Good luck! :smashin:
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Taz Having been thinking of using Fablon for my Speakerstands can you wrap it around !8mm MDF to leave no corner edge??? If i am using Fablon what should one treat the MDF with at the moment it is bare MDF debating with the missus over finish!!!
  10. Taz
    Taz
    8mm no probs mate! ;)
    Just wipe the MDF down with some degreaser (thinners etc) so it will take hold well and away you go!
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    18mm MDF Do i need to treat the MDF with anything prior to fitting fablon??? I'll get some piccies of the stands at the weekend if i can so you know what i am talking about.
  12. Exeter Man
    Exeter Man
    Sorry Taz - no Black Ash in Exeter's B&Q Warehouse.
    Couldn't actually see a gap on the shelf where it should have been either :confused:
    Regards
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    I will have a look in cardiff tonight for you Taz
  14. IronGiant
    IronGiant
    Jun 7, 2003
    62,684
    Oxford UK
    +39,863
    B&Q Oxford have a very nice display of fablon with a sheet along the bottom of the racks showing which one should be where, not individual tickets mind, this is a single printed sheet showing their complete range. Black Ash is not on it...
    Looking here :
    http://irvine.forgecom.co.uk/Chulmleigh/results.cfm?startrow=21&ct_ref=3205
    I find white ash, green ash, blue ash but not black ash, they do have plain black and black velour whatever that is.
    Dave
  15. IronGiant
    IronGiant
    Jun 7, 2003
    62,684
    Oxford UK
    +39,863
  16. Taz
    Taz
    Thnaks anyway :smashin:
  17. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Still after this Taz? I'll probably be going past a B&Q later today....
  18. Taz
    Taz
    Please :smashin:
  19. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    I have so far been unable to locate any black ash Fablon, Mate to be honest there was not much choice at all. Wikes dont stock any.
  20. IronGiant
    IronGiant
    Jun 7, 2003
    62,684
    Oxford UK
    +39,863
    Taz,
    I thought my post also made it clear that B&Q don't seem to do black ash fablon anymore and that Fablon seem to have dropped it fromtheir range.
    I found a possible alternative that you could get on the net and you ignored that post too...
    As a newbie on this site I don't want to **** anyone off, but it seems odd you're ignoring my input
    Dave :confused:
  21. Taz
    Taz
    Sorry Dave, Im not Ignoring you input mate :blush:
    Im gonna order from the site you gave me as I cant find the Fablon anywhere it seems.
    :smashin:
  22. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Must admit I was wondering the same thing myself, Dave....
    Taz, I was wondering, how do you do the edges with Fablon. I can see you could go round 4 sides - top, side, bottom, side, but what about front and back? Don't you get a nasty seam?
  23. IronGiant
    IronGiant
    Jun 7, 2003
    62,684
    Oxford UK
    +39,863
    Glad to be of help Taz :D
    Dave
  24. Taz
    Taz
    Dave,
    Thought id let you know I ordered 5 metres black ash today, have to send a cheque but including postage it was £11.
    ReTrO: £11 off your money ok?
  25. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    Yeah, good with me.
  26. IronGiant
    IronGiant
    Jun 7, 2003
    62,684
    Oxford UK
    +39,863
    I planned to paint mine, but I'm getting round to the idea.
    Problem is I built my first set of speakers out of old dismantled radios acquired from jumble sales, put into a chipboard box, covered in vinyl, and the front baffle (exposed) was 1/4 inch plywood covered in, you guessed it, fablon. That was probably around 1976.
    Fablon brings up painful memories...
    Dave
    PS: Let us know what it looks like, because I might well want some myself.
  27. gazsnk
    gazsnk
    hi could you tell us where you ordered your black ash from im after some at least 750mm wide cheers gareth
