F.A.O. Ramius
Discussion in 'Home Cinema Speakers' started by Jase, Mar 28, 2002.
  1. Jase
    Jase
    Mar 16, 2001
    10,822
    United Kingdom
    +2,713
    Hi Boris
    I downloaded the test tones in 2 hz steps from 10hz thru to 100hz, unfortunately a few havent downloaded properly so they are missing.
    The test tones were played back at -20db on my master volume (Denon) and Digital sound meter set at C-Weighting Slow.
    For your reference the system is balanced to 75db via AVIA which equates to -13db on the Volume level.
    Here are the raw results.
    10hz - 83db
    12hz - 84db
    14hz - 83db
    20hz - 88db
    22hz - 88db
    24hz - 84db
    26hz - 86db
    28hz - 88db
    30hz - 89db
    32hz - 91db
    34hz - 91db
    40hz - 92db
    42hz - 91db
    44hz - 91db
    46hz - 92db
    48hz - 91db
    50hz - 91db
    52hz - 89db
    54hz - 90db
    60hz - 92db
    62hz - 90db
    64hz - 88db
    66hz - 86db
    68hz - 87db
    I dont think it looks TOO bad but what are your thoughts??
    cheers
    Jase
  2. Ramius
    Ramius
    Oct 13, 2000
    1,093
    Yorkshire
    +308
    Jase, cancel your BFD order. :)
    That's very flat. It's just about +/-2dB.
    You're getting some great room gain under 30Hz.
    No peaks or nulls.
    Seriously, I wouldn't bother with the BFD.
    Check all the way upto the crossover point though.
    Boris
  3. Jase
    Jase
    Mar 16, 2001
    10,822
    United Kingdom
    +2,713
    :D
    Excellent!! The BFD order was about to be processed so I´ve cancelled it now, bit of shame for the company as they were very quick to respond (and the only one of four!!).
    I´ll download the remaining frequencies up to 80hz (my crossover) & see what results I get.
    To be honest the sub sounds pretty good anyway (considering my "room"!!;) )
    cheers Boris!!
  4. lmccauley
    lmccauley
    Oct 24, 2000
    3,563
    Newcastle
    +346
    Jase, out of interest, where did you download the tones from?
    I tried generating tones and burning a test disc but it didn't seem to work properly.
    Cheers,
    Liam
  5. Jase
    Jase
    Mar 16, 2001
    10,822
    United Kingdom
    +2,713
    Courtesy of Ramius
    http://www.snapbug.ws/sinewaves/
    Just right click on each tone and save to whatever file you want.
    MP3 format. I downloaded at work, copied across to home via a Zip drive and burnt them onto CDR.
  6. Ramius
    Ramius
    Oct 13, 2000
    1,093
    Yorkshire
    +308
    Jase, I hope you don't find this question insulting but you did take those measurements at the listening position, yes?
    Boris
  7. Jase
    Jase
    Mar 16, 2001
    10,822
    United Kingdom
    +2,713
    Yep!
    Meter was where my head would be.
  8. Ramius
    Ramius
    Oct 13, 2000
    1,093
    Yorkshire
    +308
    Well you're laughing then. :D
    Thats a response you'd be happy with after EQing.
    Boris
  9. Jase
    Jase
    Mar 16, 2001
    10,822
    United Kingdom
    +2,713
