eyestrain from hidef material?
Discussion in 'General TV Discussions Forum' started by Laura, Aug 6, 2004.
  1. Laura
    Laura
    Mar 8, 2002
    397
    Newcastle Upon Tyne
    +24
    My copies of Speed and Coral Reef IMAX WMVHD DVDs have just turned up.
    Started watching them on my PC, and finding my eyes are getting tired watching.
    Running on a 21" monitor at 1280x960 (film letterboxed into 1280x720) at 85Hz
    Also got it on other HDTV material - Harry Potter CoS and StarGate Atlantis.
    Hopefully i won't get this when i show it on a projector (still waiting to get my projector once my house move is completed).
    Has anyone else experienced this?
  2. Laura
    Laura
    Mar 8, 2002
    397
    Newcastle Upon Tyne
    +24
    OK, looks like it's just the 85Hz thats the problem...
    Turned it down to 60Hz and movie playback is fine - though the desktop now shimmers something rotten,
  3. Abit
    Abit
    Jul 28, 2004
    222
    16
    California, USA
    Try 70, 60 is too slow.
  4. IanPM
    IanPM
    Jan 12, 2004
    389
    +6
    If your monitor can handle 100hz you will probably find that much better.
  5. Laura
    Laura
    Mar 8, 2002
    397
    Newcastle Upon Tyne
    +24
    Unfortunately at 1280x1024, my monitor will only go to 85Hz.
    The 60Hz for the IMAX stuff seems to be the best for my eyes at the moment.
    Will play more when I actually get a projection device capable of 720p
    I'd be interested to know what refresh rates other people are using
  6. IanPM
    IanPM
    Jan 12, 2004
    389
    +6
    Actually, I have just had a thought, you might like to give this a go and tell us how you get on.
    Set your monitor back to 1024x768, and 100hz, try that and see if its any beter. While the picture will be downsized it will give you an idea of wether or not 100hz helps. If it does, and you want to use a monitor for watching some HD material you might consider buying a new one.
    But anyway, it might be worth a try :)
    I'm using 1024x768 on my dual monitor set-up, both screens are set to 100hz. My processor isn't quite up to most HD stuff at the moment, but the 720p material looks great like this.
