eyeline pro IR extender
Discussion in 'Projectors, Screens & Video Processors' started by manka, Aug 23, 2017.
  1. manka
    manka
    Dec 8, 2007
    237
    28
    +49
    Hi peeps
    I've got a screen and I'm trying to use the IR extender that came with the screen to run it behind the screen casing (with an extension) and run it to my broadlink rm pro, with the intention of using Alexa to bring the screen down with voice. However the ir only seems to work when it's within 10cm and placed directly above it head on.... My experience has always been positive with an ir extender so just wondering if I could use a different one instead. The extension cable I'm using is 5m long...not sure if that has any impact?
    Thanks for looking!
