Eyefinity Monitor advice and recommendations
Discussion in 'What Is The Best TV For You?' started by Chrisoldinho, Sep 6, 2012.
  1. Chrisoldinho
    Chrisoldinho
    Feb 7, 2006
    3,445
    Leeds
    +267
    Hello everyone,
    I am looking for advice please on what monitors to get for an Eyefinity setup.
    My budget is £120 per monitor approximately.
    In terms of requirements, 22" size would be good, but willing to consider anything from 19" upwards, I am getting a 120cm table, as I understand 3 22" monitors should fit (just).
    Resolution wise, anything from 1600x900 upwards, 1080p is preferable as I have 2 HIS 7950 IceQ's so should be ok performance wise.
    Probably asking the impossible at this price, but looking for something with a small bezel, good contrast ratio. I don't know whether to go with an LCD, LED or IPS panel.
    Connection wise, HDMI / VGA / DVI is really all I care about, DisplayPort is a luxury at this price range, and not a requirement.
    Any thoughts appreciated, Chris.
  2. Orson
    Orson
    Feb 21, 2002
    3,286
    Sunny Ilson, pride of Derbyshire!
    +669
    <<< Thread moved >>>
