Teun87
Hi everyone,
A week ago I bought a new TV after months of money saving
I did a lot of research and selected the LG OLED55B7V (55 inch) in the end. I like the fact that it is so slim and the OLED technique looked the most impressive too me, compared to others such as QLED.
My previous TV was also a LG, but a regular HD 32inch model from +/- 2014.
After mounting it on the wall I could finally enjoy my new TV. But, then the problem started... After a few minutes a massive headache started. Since everything looked very bright I reduced the OLED lightning, contrast and brightness. It seemed to help but my eyes still kept watering. I decided to go to bed and give it another try on the next day.
Days later I literally tried almost every setting and nothing seems to completely solve my eye problems. By the way: I only experience real problems with my left eye (eye strain, watering, irritations). I do sleep bad (6 a 7 hours) and make many hours behind computer screens.
I also emailed LG care center about this. They advised me to try out the Eye motion care option and the Eye comfort mode. I both tried the options. The Eye comfort mode did help a bit, the Eye motion care option seemed to improve nothing
My setup at the moment:
Can anyone give me tips or a solution? Maybe ultimate settings
I'm so disappointed and thinking about returning the TV or get another model.
Thanks,
Teun
- 280cm distance, couch is perfect in front of the tv
- Extra environment lightning (not behind the tv, just a small lamp next to the TV)
- TV is attached to a wall mount at 61cm height
- Cinema mode
- OLED: 70
- Contrast: 70
- Brightness: 40
- Sharpness: 10
- Motion Eye care is on
- Eye comfort mode is on
- 2.2 (white balance??? Need to check)
Thanks,
Teun
