Eye`s FRONT !!
Discussion in 'Home Cinema Speakers' started by NastyButNice, Feb 20, 2001.
  1. NastyButNice
    NastyButNice
    Just building my first pro home cinema system(but on a budget,Of course !!) which consists of an Yamaha DSP-A5 Amp and a Tannoy MXC Centre speaker at the moment, i want to get a good set of front speaker`s for it!,any ideas which speakers would sound good with this system so far ?.
    Thinking about some Mission speakers but not really sure which ones will sound good with the Tannoy centre, Also thinking about the matching tannoy speakers which seem to cost about £30 more than any other speaker ??!!.
    Any ideas
    Ian
  2. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    It is imperative that you match the fronts with the centre, pay the extra 30 quid. alternatively go for something other than the Tannoys, making sure that the fronts and centre match, eg mission or kef setups.
  3. fishyben
    fishyben
    Can you explain why it is imperative that you match the fronts with the centre [​IMG]
    and why you can't mix front and center brands.
    Thx, ben
    http://dvdstuff.at/fishyben
    [This message has been edited by fishyben (edited 11-03-2001).]
  4. Radioactive__Man
    Radioactive__Man
    Jan 13, 2001
    967
    Scotland
    +18
    Maybe not imperative, but certainly advisable. The speaker manufacturer will try to match the sensitivity and audio characteristics of the centre & main speakers, this is because they will be sharing certain frequencies, so you dont want a mismatch in the mid and upper ranges of the speakers.
    If they are different [i.e. different manufacturers] you will have to adjust effect levels, cut-offs and [if you have a top end amp] equaliser settings for the centre speaker, from your AV amp.
    Also if you buy the speakers from a particular range, they should be of equal sonic qaulity, and if it matters to you or your partner should look similar in construction and finish.
    BTW all my speakers are Mission, except for my sub which is Paradigm
    Put the bunny back in the box !
