Eye-level low and long?
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by marmite0, Jun 30, 2005.
  1. marmite0
    marmite0
    Jun 24, 2005
    122
    +5
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    Ikea should have something suitable - I use the Benno stand which has sliding glass doors but many users here like the Oppli. :)
  3. marmite0
    marmite0
    Jun 24, 2005
    122
    +5
    Thanks for the ikea tips.
    No offense, but I don't like the look of them. The US site offering IMO look much nicer..
    I'm surprised there are not more companies offering plasma centres of this sort..
    Any other pointers greatfully received.
  4. ian.webb
    ian.webb
  5. marmite0
    marmite0
    Jun 24, 2005
    122
    +5
    That's more like it ;)
    That looks to be about the dimensions I'd like.
    May I ask where did you buy or was it made?
    Is that 42" btw?
    I'd consider something like that, though wife is keener on more high-tech glass and metal I think, matching cd/hifi rack, but I think asthetically the size/dimensions and all important viewing height are much better with your type of setup.
  6. ian.webb
    ian.webb
  7. marmite0
    marmite0
    Jun 24, 2005
    122
    +5
    :D
    Well, I might sound like I'm being smart after the fact, but I had my suspicions it was a modified piece of furniture, becuase the best I've seen elsewhere was something in Oak which was also a bookshelf, though he/they had just layed on side and knocked out a few shelfs + added feet.
    Excellent job you've done, I'm DIY-phobic, so I'm in a cold sweat now thinking about it - I have to buy something that involves no more than assembly.
    Anymore offering anyone? :confused:
    Me thinnks there is a market out there for an industrius stand/furniture maker! Admittedly a lot of people wall mount, but there also plenty who've opted for CAB or PED versions so there's is a demand for nice non-wall mounted options and surely. It seems most of the usual manufacturers do not build low enough units.
    Ho-hum, the search continues..
  8. ian.webb
    ian.webb
    There are a couple of places you can try which are listed below. I went through the same process that you are currently going through but I couldn't find anything in the right size or price range. Hence the DIY job. If your interested in doing the DIY job yourself there are only two saw cuts the rest is just used in a differrent way than Ikea planned.
    I deleted most of my previous links but if i come across anymore I'll let you know.
    http://www.boconcept.co.uk/Default.asp?ID=9766
    http://www.neuliving.co.uk/
    http://www.quadraspire.co.uk/
    http://www.jesse.it/
    http://www.molteni.it/
    http://www.hulsta.com/
    http://www.lemamobili.com/
    http://www.vogels.com/product/products.aspx?pg=11&id=141&taal=2
  9. marmite0
    marmite0
    Jun 24, 2005
    122
    +5
    Thanks for that Ian.
    There's a least one possibility in there.
  10. johndickinson
    johndickinson
    Jan 9, 2003
    369
    28
    +25
  11. Tellyfiend
    Tellyfiend
    Jan 21, 2005
    225
    +13
  12. FunkyMonkey
    FunkyMonkey
    Dec 11, 2002
    1,491
    48
    +83
    Be sure that each compartment is wide enough for your av gear! Just somethign to be wary of. Good luck. :smashin:
  13. mat1110
    mat1110
    Feb 2, 2004
    83
    do the walls of the compartments come out then that wouldnt matter
  14. Puzzler
    Puzzler
    May 15, 2007
    61
    +3
  15. bertha
    bertha
    Oct 25, 2001
    1,303
    +89
  16. FunkyMonkey
    FunkyMonkey
    Dec 11, 2002
    1,491
    48
    +83
    www.dwell.co.uk for something cutting-edge, individual, modern and affordable.
