Extraordinary League of Gentleman R1
Discussion in 'Movie Forum' started by GJC, Dec 17, 2003.
  1. GJC
    GJC
    Mar 1, 2002
    2,095
    London
    +65
    My pc dvd writer (freecom - which I believe is an NEC 1300 clone)
    Is set to R2 and I have slysoft (licensed) AnyDVD running in the background - when I run dvd decryptor or dvd shrink it refuses to work with Ex. Ord. Lge. Gent. or Xlg.
    Many hours of messing around and the only way to allow Dvd Decryptor to work was to change the region on the drive and close AnyDvd.
    Regards,
    GJC
  2. RobsterD
    RobsterD
    Dec 11, 2000
    870
    Southampton
    +12
    Had real problems running that disc on my HCPC with a Pio 120s and the A05 both seem to struggle,at one point Theatertek stopped totally and had to reboot the PC,works fine without any glitches on my conventional DVD.
    Managed to rip it to my hard drive OK with decrypter,but haven't tested to see if it's OK yet
  3. GJC
    GJC
    Mar 1, 2002
    2,095
    London
    +65
    I have had real problems with AnyDvd and my system:
    P4 2.66ghz
    768 ram
    80 gb Hd, 40 gb Hd,
    Freecom Dvd_+/- RW4B
    Lite-eon Cd R/w
    Windows XP Home
    Nero 6
    Norton A/Virus 2003
    Norton Firewall 2004
    Dvd Software:
    Win DVD 4.0 (licensed)
    Interactual Player
    Basically Anydvd Player doesnt play the dvd.
    It also prevents Dvd Decrypter from removing the protection on 'The League of Extraordinary Gentleman (R1) - I had to change my dvd drive region to match the film in order for Dvd Decrypter to work.
    Playing back the film with Anydvd active is a nightmare the film stutters etc, you cant watch it. Switch it off and the film plays. (Only because, the drive region has been changed).
    I will be contacting slysoft tech support tonight for some answers or a refund.
    FYI - I downloaded Dvd Region Free and it works fine.
    Kind Regards,
    GJC
  4. GJC
    GJC
    Mar 1, 2002
    2,095
    London
    +65
    AnyDvd from Slysoft.
    The Technical support department - DO NOT GIVE REFUNDS IF THERE PRODUCT DOESNT WORK ON YOUR SYSTEM EVEN IF IT PERPORTS OTHERWISE.
    My advice try it before you buy it.
    However the version I tried before I brought worked better than the most recent 3.2.1.0 ver.
