Afternoon all, calling on the GC knowledge re fans...!
Just had a new extractor fitted in our bathroom as the old one was crap. Was hoping this would solve the problem but the bathroom is still full of steam which won't shift until the window is wide open. I don't think the fan is very powerful but I think the venting is probably half to blame too. Looking in the loft the fan is vented through the circular tumble dryer style pipes. The other bathroom also has an extractor so they both seem to go into a t shape piece which then goes to the vent to outside on the wall. There's loads of piping though, probably a good 5m between the fan and the outside vent. I doubt it going into some sort of connector is helping either.
I don't really want to cut a hole in the roof to fit another vent, is there any other way to vent it? If not, I assume I'm going to need something pretty powerful to make it shift through so much piping? Planning on going up with a load of tape to make sure the pipes are all sealed to the connector etc but can't see it helping too much. The bathroom ceiling has cracked a fair bit I reckon is down the the moisture so hoping to get this sorted...
Thanks!
Thanks!
