Extraction fan knowledge
Discussion in 'General Chat' started by davidegee, Jan 19, 2018.
Tags:
  1. davidegee
    davidegee
    Aug 9, 2007
    1,224
    Cambs
    +352
    Evening,
    I have a xpelair model 90843AW in the bathroom from when we moved in. The led comes on when the main light is switched, so it's powered, but it's not actually worked since we've been there.
    It doesn't look like the model is in production anymore, so a direct replacement is pricey, but I'd rather not have to mess with ducting and so on. I'm wondering if anyone knows current xpelair model that would be a like-for-like in terms of fittings, ducting size etc for the 90843AW, please?
  2. stuart07970
    stuart07970
    Sep 28, 2004
    2,628
    Slough
    +359
    Google isells
    They have a good website and a good range
    However if there’s a loft above the bathroom do the right thing and make a little effort and install an in-line fan in the loft - you’ll be so glad you did
  3. rousetafarian
    rousetafarian
    Aug 17, 2007
    23,864
    2
    NW
    +15,880
    A farmer friend of mine used to have a massive collection of John Deer and Massey Ferguson’s literally he had that many of them he lost count, he was obsessive. His long suffering wife couldn’t cope with the competition so she left him for a neighbouring farmer’s young son.
    Finally gave up the hobby and massive collection, that kind of ex-tractor fan?
    • Like Like x 3
    • Useful Useful x 1
    • Funny Funny x 1
    • List
  4. Wahreo
    Wahreo
    Oct 11, 2012
    15,444
    +12,732
    Funnily enough, I just bought a Positive Input Ventillation System from Amazon and when it came I noticed the seller was ‘isells’
  5. ufo550
    ufo550
    Sep 20, 2014
    1,535
    113
    Oxfordshire
    +851
    You could contact Xpelair, and ask if they have a replacement part;
    Spare Parts
    But probably just as cheap & quick, to obtain the their replacement model.
  6. Wahreo
    Wahreo
    Oct 11, 2012
    15,444
    +12,732
    David, I would just go out and buy an extractor fan grille and an in-line fan and just replace it.
    The ducting is more than likely to be the same size- you might just need some cable ties to fix the ducting on to the fan and grille.
    There will more than likely be enough dicting already there. Just break into it with a Stanley knife and cut the wire in the ducting with some wire cutters.
    Obviously I have no idea of the set up you have so this is based on how I think it will go, your set up might be different.
  7. ufo550
    ufo550
    Sep 20, 2014
    1,535
    113
    Oxfordshire
    +851
    I agree with your advice. However, a quick search of that discontinued model (number), suggest it might just be a humidistat model. Best check with the manufacturer, or inspect the wiring supply, before replacing with something different.
  8. stuart07970
    stuart07970
    Sep 28, 2004
    2,628
    Slough
    +359
    if you’ve got good access from above consider putting a larger 125mm or 150mm grille - it’s all about airflow
    Likewise an in-line will probably give you 259m cubed (per hour)of air movement
    Your surface mount one is probably about 85m cubed
  9. davidegee
    davidegee
    Aug 9, 2007
    1,224
    Cambs
    +352
    Thanks folks. The existing extractor is wall mounted but I'm going to look into ceiling mount inline. There's a seperate shower room too so I need to check in the loft to see where that vents to as I may be able to hook into it.
  10. its_all_Greek
    its_all_Greek
    May 8, 2009
    4,789
    Nottingham
    +2,609
    If You do tap into the shower fan then a couple of inline "Flap valves" will be required to prevent one room venting into the other.
  11. Wahreo
    Wahreo
    Oct 11, 2012
    15,444
    +12,732
    Be a bit careful with those shutters. They don’t tend to seal particularly well and can sometimes cause a back draft into another room.
    Best bet is two separate ducts to atmosphere or if you do use one, fit the ‘Y’ branch as close to the terminal as possible.
