Extract audio from DVD-R
Discussion in 'Blu-ray & DVD Players & Recorders' started by SmokyToby, Jan 13, 2004.
  1. SmokyToby
    SmokyToby
    Nov 26, 2003
    35
    Ipswich, Suffolk
    I just wondered if anyone knows if the following is possible:
    I have recorded several music concerts onto DVD-R via my Panasonic E50. What I would like to do is use the DVD-ROM drive in my PC to copy the audio "content" and burn on to a CD-R in my CD writer drive - so I can play it in the car etc. Is there any software that can do this?
    Neil
  2. applevenus
    applevenus
    Yes, lots. Visit http://www.dvdrhelp.com for information.
    Basically what you're going to do is 'demux' the vob files on the DVD-R.
    You won't need to 'rip' the DVD since there is no copy protection on the disc - just copy the vob files to a folder on your PC.
    When you demux you separate out the audio and video assets.
    the audio will probably be .ac3 format however there are tools (listed on the site I mentioned) that will convert for you.
  3. SmokyToby
    SmokyToby
    Nov 26, 2003
    35
    Ipswich, Suffolk
    Thanks applevenus. I will give it a go!
  4. clayts450
    clayts450
    Jun 25, 2001
    562
    2
    Nottingham
    +51
  5. SmokyToby
    SmokyToby
    Nov 26, 2003
    35
    Ipswich, Suffolk
    Thanks clayts450
    Looks fairly straightforward - just what a non techie like me needs!
