RichardN75
Right, bear with me whilst I ask this, as it's probably not complicated to you lot, but I'm still learning!
I have a flat, where the only TV point is in the lounge. There are two bedrooms, and I wish to run an aerial point in each. In the master bedroom, I wish to run Sky Magic Eye so I can change channels from my bedroom, but the second bedroom only requires standard terrestrial channels.
In the lounge at the TV point, it has a normal terrestrial RF point, and one for the Sky feed. Obviously it being a block of flats, the signal is split between the three flats.
There is no other cabling in the house, but I currrently have all the skirtings off after having new flooring laid, so I can very easily run cabling round the flat if required.
Equipment wise, I have a 42" Samsung LCD in the lounge, with a yet to be decided surround setup DVD, and Sky+, and a 32" Samsung LCD to go in the bedroom with a simple Samsung surround setup with DVD player.
What is the most simple way to pipe the TV signal round the flat to do as described? I can manage the fitting of sockets and cable myself, so that is not an issue.
Will I need any sort of VHF/UHF amp before the signal is split?
Any help would be much appreciated....
