Extra surrounds sony Str-db1080
Discussion in 'AV Receivers & Amplifiers' started by ere, Nov 8, 2003.
Tags:
  1. ere
    ere
    The sony Str-db1080 is a 6.1 dd ex/dts-es amp.
    1. Is it possible to add a second surround back 8ohm speaker in series with my existing 8ohm speaker as the amp only allows for one.
    2. Is it possible to do the same with each of the surrounds eg. making the sound field, surround left1, surround left2, surround right1, surround right2.
    I am asking these questions as my living room is 25 foot long and i would like to be able to fill the void down the side walls.
  2. thackl
    thackl
    Jul 7, 2003
    46
    Sydney
    You can add as many speakers as you like if you use external amps that run from the pre-outs of your existing AV amp.
    Have a look here.
    http://members.optusnet.com.au/~thackl/gallery.html
    Was discussed in detail in a thread titled 'Second centre speaker' in amps & receivers
    Tom
