Extra Long Scart Cable
Discussion in 'Cables & Switches' started by Spursman, Jun 30, 2005.
  1. Spursman
    Spursman
    Jun 28, 2005
    403
    +24
    I am setting up my LCD which needs to be plugged into Sky. I am mounting my LCD on the wall and dont want all the wires to be showing.
    Is there a scart cable longer then 10m??
  2. loadsofleads
    loadsofleads
    Hi, they are available, Supra don't do 'off the shelve' 10 meter scart cables but they could build one to your requirements if needed, wouldn't be cheap though :eek:
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,413
    The Borders
    +2,590
    Spursman
    'Fully Wired' at 10m+ are relatively rare - though worth checking out a couple of the banner adds on these pages just in case.
    A custom RGB only cable from the likes of VanDamme will cost you around £100.00 - whilst the Supra RGB only cable will be nearer £200.00.
    Best regards
    Joe
    PS If its SKY+ have you had a look at it via S-Video - I find a lot of LCD's look pretty good with S-Video and it would be a lot less expensive than a decent 10m+ SCART cable.
  4. nathsea
    nathsea
    Apr 26, 2003
    917
    +24
  5. nevC
    nevC
    Oct 13, 2002
    109
    Ireland
    +3
    Bought a 15m cable from cableuniverse.co.uk and find it has a more stable brighter image than that provided by a 12m S-video cable. However I cannot get a picture from a non RGB source such as VCR or SKY digibox.
