Extra long PS2 S-VIDEO cable.
Discussion in 'Playstation Forums' started by lotusman1, May 25, 2004.
  1. lotusman1
    lotusman1
    Feb 13, 2002
    277
    cheltenham
    Any idea where i can get an extra long S-VIDEO cable so i can plug it into my PJ mounted on the ceiling.Also the phono jacks need to be able to split from the cable so i can plug those into my amp on the other side of the room.
    TIA marc.
  2. azzo
    azzo
    Feb 13, 2002
    1,009
    38
    Wokingham
    +9
    Why don't you just buy an av adapter, I think they are available from the sony web site for around 15 quid, then buy an s-video cable to plug into it.
    Alternatively I remember Monster cable do a long s-video cable.
    If your pj does component then this would be an even better choice.
    Azzo
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    just get a coupler and the right length S-video cable to PJ, Also why not use optical for sound?
