Extra 50p discount on top of the £2.50! No way! Way!
Discussion in 'Shopping, Deals, Discounts & Bargains' started by simon1967, Dec 1, 2003.
  1. simon1967
    simon1967
    Jul 1, 2002
    622
    SE London/Kent
    +8
    I know, I know, it's no big deal but count the pennies etc, etc. If you have been ordering, you may have noticed the little CD-Wow credit card type voucher that comes with your delivery. This code can be used in addition to the £1.50 Trustcard AND the amex £1.00 discounts. I guess that is because the £1.50 is classed as an e-voucher and the 50p discount is entered in a different box (can't remember the exact name). Anyway, all these 'bargains' means I ultimately spend more in the long run:rolleyes:
    simon
  2. SkullyRox
    SkullyRox
    I have definitely spent loads more than I ever would normally on there recently! Bought most of my christmas gifts on there. :D
    Bought one thing from Blackstar, which has yet to turn up... tomorrow will be 8th day... eek! :eek:
  3. DaveP
    DaveP
    How do you get back to the voucher screen? Do you click on "Back" or re-type the URL?
    Dave
  4. SkullyRox
    SkullyRox
    Oh yeah, that's a point! I guess, you go to check out, redeem one voucher, then, close the page, and erm.. maybe do the same again? Na, that won't work... Hmm.
  5. Jez
    Jez
    Oct 30, 2003
    468
    19
    Lincoln
    It doesnt work cause have already tried
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    NO you have to choose which voucher you are going to use, £1.50 or 50p its up to you!!!
    I give the 50p ones away to help CDwow!!
  7. Rediffusion
    Rediffusion
    Aug 26, 2003
    33
    9
    Brooklyn, NY
    has anybody got this to work or is simon1967 wrong?:confused:
  8. ScoobyZ
    ScoobyZ
    Sep 29, 2003
    921
    +56
    No it doesnt work :(
  9. simon1967
    simon1967
    Jul 1, 2002
    622
    SE London/Kent
    +8
    Sorry, haven't been checking my mail lately. I've placed three orders using this method so it does work. What I did was when you get to the voucher screen (before the amex trick), you put the trustcard number in the e-voucher box and the cd-wow voucher in the box above it. Press go and both 'should' be discounted and then you go to continue shopping, amend the url to amex and get your extra pound.
    Just to prove I'm not going mad, I've found another 50p voucher which I'll try and post back the results. Now where's my credit card....
  10. simon1967
    simon1967
    Jul 1, 2002
    622
    SE London/Kent
    +8
    Just did it and it worked, no problemo. It did work slightly differently this time in that it only showed the 50p off when I pressed enter so I cut the 50p voucher from the box just to check whether my £1.50 voucher hadn't already been used and it then showed both vouchers. Then moved onto the amex link and the rest as they say is history. Just as proof and to get extra smartass points, I bought a game with it instead.
  11. philipjg
    philipjg
    Dec 18, 2002
    112
    Preston
    +3
    thanks Simon, I'll be giving that a go
  12. Rediffusion
    Rediffusion
    Aug 26, 2003
    33
    9
    Brooklyn, NY
    My appologies, you're right - it works!....
    ÊÊÊÊÊÊDVD Region 2 - MASH: Special Edition (2 Discs) £5.99
    ÊÊÊÊÊÊTotal Order Value: £5.99
    ÊÊÊÊÊÊRedeemed Gift Voucher: -£0.50
    ÊÊÊÊÊÊRedeemed Gift Voucher: -£1.50
    ÊÊÊÊÊÊTotal payment: £3.99
    The trick is to click on the first GO button and open in new window. While that's opening, click on the other GO button.
    Worked a treat!
    Thanks Simon;)
  13. Herbal
    Herbal
    Are these the ones from Cdwow, when you do an order?
    As threw all mine out as didnt see the point in keeping them
    AHHHHHHHH
  14. bungle1979
    bungle1979
    Sep 11, 2003
    49
    11
    +4
    Can't seem to get it to work - which 'go' button do you press when you've typed in both vouchers (simultaneously, I presume)?
    Is it the WOW voucher or the web voucher?
  15. PaulJ
    PaulJ
    Worked fine for me!
    Cheers Mate :smashin:
  16. DaveP
    DaveP
    This is excellent! MASH Season 5 pre-ordered for £14.99!:clap:
    Dave
  17. jdanielp
    jdanielp
    Jun 20, 2002
    176
    Edinburgh
    +3
    hmm, can't get this to work, does anyone have a better explanation for getting the two vouchers to be applied at the same time? :lesson:
  18. gouryella
    gouryella
    Sep 8, 2003
    1,464
    38
    +19
    Would anybody be so kind to pm me how to do this as i cant seem to get it to work or alternatively just post it. Cheers.
  19. THFC
    THFC
    Feb 24, 2003
    242
    Gloucester
    +5
  20. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    Yes, this does work.
    As mentioned before the trick is to enter both codes. Click one of the go buttons then straight away before the new page opens click the other.
  21. SkullyRox
    SkullyRox
    Gift Voucher £-1.50
    Gift Voucher £-0.50
    YAY! All you do is click go on one then right away the other. :)
  22. jdanielp
    jdanielp
    Jun 20, 2002
    176
    Edinburgh
    +3
    bizarre, i am sure i tried everything yesterday but it wouldn't work and now it works straight away... ah well :clap:
  23. RL123
    RL123
    Nov 4, 2002
    1,037
    38
    +4
    Does anyone have a working £1 (or £1.50) voucher? Or have they all expired now...
  24. Jimbobgod
    Jimbobgod
    Feb 23, 2003
    St Albans
    Although I can get the £1.50 e-voucher, for some reason I'm not getting the Amex 50p...and I feel deprived! Can someone PM as to how to get it please?? :smashin:
  25. THFC
    THFC
    Feb 24, 2003
    242
    Gloucester
    +5
    I understand the following
    a: How to get the £1.50 E-voucher by trustcard format ie - 9B3TY-CLJ99-B88KL-8UBHQ
    b: How to get the £1.00 off via amex link afterwards
    Now understand you can get a further 50p by entering another code on the checkout voucher page under Cd wow voucher. Format different ie - 9B3-CLJ-B88-BHQ
    Where do you get these 50p codes in this format? I know they appear on the credit card style vouchers. But are they available elsewhere.
    point is i want to order 15 cd's before xmas and 50p more on each is a saving
    thanks
  26. THFC
    THFC
    Feb 24, 2003
    242
    Gloucester
    +5
    Noticed the cd wow vouchers (not E vouchers/trustcard) on the checkout page go from 50p to £8.99
    As does the freeserve link
    cannot get this to work though - no code delivered to various email addresses
    Weird - Got 10 trustcard vouchers also yesterday and today can get none.
    Removed History/ Temp Internet Files/ Cookies
    No joy
    Please pm
  27. SkullyRox
    SkullyRox
    50p here was from little card that comes in your order.
  28. Rediffusion
    Rediffusion
    Aug 26, 2003
    33
    9
    Brooklyn, NY
    Thanks to this method I just bought...
    Album(s): ÊÊ MOCK TURTLES - Can You Dig It - The Best Of The Mock Turtles
    Price: ÊÊ £0.74
    It was originally £2.99
    I could only get the 25p off affid to work [12863]
    Is this the cheapest yet or have you done better?
  29. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    I too apologise! need to stop throwing the 50p vouchers away then!!!
    One problem with this is i have spent at least £100 on discs i wouldnt normal buy in a month! seasons 1-5 of sexy and the city, season 5 twice, (dont ask) and loads of others, Mind you the indy box set is looking mighty tempting now!
  30. chris6364
    chris6364
    God know's how i've done it, but whilst on CDWow and ordering a certain title (not naming it just in case it gets cancelled!!) (£15.99 then £12.99 using the right methods) i went to the checkout page, loaded the vouchers, then decided not to buy it. Removed it. Then decided to buy it, added it back into my basket, then went to checkout again and it was asking for £8.99!!! What i thought!!
    Here's my e-mail confirmation though!!
    Thanks for shopping at CD WOW! We have pleasure in confirming your order:
    Your order number is 1xxxxxxx.
    IF YOU HAVE ORDERED MORE THAN ONE ITEM, EACH ITEM WILL ARRIVE UNDER SEPARATE COVER
    DVD Region 1 - £14.99
    Total Order Value: £10.49
    Total payment: £8.99
    Thank you!
    Each item will be packaged and dispatched individually to:
    ...if anyone knows whats going on here you could net a very cheap bargain!!!
